MSI Radeon RX 5700 XT Evoke OC Review
September 11, 2019 | 14:00
Tags: #gpu #graphics-card #navi #navi-10 #radeon-dna #radeon-rx-5700-xt #rdna
Companies: #amd #msi
Overclocking
Overclocking is still buggier and less reliable than it tends to be with Nvidia hardware, and you should never assume that what we manage with one card is applicable to others, as even within the same model there is silicon-based variation.
For this sample, we simply set every main slider to the highest available values in WattMan. This meant a 120 percent power limit, a 2,150MHz maximum value in the core frequency curve (the curve auto-adjusts itself based on the value you enter), and 950MHz on for the memory frequency, which takes you to 15.2Gbps effective.
You can see some results of the card when in this overclocked state in the graphs below.
